It is currently Thu Sep 18, 2025 3:54 am
 Post subject: Need Advice!
PostPosted: Sat Jun 07, 2014 5:46 pm
First name: Wizard
Last Name: Kelly
City: Lafayete
State: LA
Zip/Postal Code: 70506
Country: United states
Hello everybody, I'm Wizard.
I would like some advice on where to start. I have no woodworking experience and no tools.
I'm really interested in building classical and acoustic guitars.
Any advice on getting started is welcome and appreciated :D
 Post subject: Re: Need Advice!
PostPosted: Sat Jun 07, 2014 5:48 pm
Hi Wizard! I started with a Martin kit and would recommend any first timer to start with a serviced kit. Several of our sponsors sell them. Kits will allow you to get started with minimal tooling. I'm sure you will get lots of advice and encouragement here at the OLF.
These users thanked the author LanceK for the post: Wizard (Sat Jun 07, 2014 6:53 pm)
PostPosted: Sat Jun 07, 2014 5:52 pm
First name: Wizard
Last Name: Kelly
City: Lafayete
State: LA
Thanks Lance!
Another question:
I see a lot of back and side kits...Where do I get the fronts ?
PostPosted: Sat Jun 07, 2014 6:29 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Hi Wizard,
I'm a relative newcomer to lutherie and am building guitars and ukuleles. I agree with Lance that a kit is a great idea. If I were just starting now, I would first purchase an online building course from Robbie Obrien (O'brien Guitars) for either steel string or classical, and watch the whole thing before buying and starting. Robbie is a great teacher and the classes show how to do many processes with alternative tooling for those with different levels of tooling. This will allow you to see the entire process. He addresses everything from assessing the wood to finish and setup. I followed his methods through 2 of my builds, and I don't do any building without referring back to some of the chapters.
As Lance mentioned, many of the sponsors offer kits (Bluescreek Guitars, Luthiers Merchantile Intnl, and StewMac).
Finally, this forum is a wealth of information on all aspects of building and finishing, and there are many experienced builders who give generously of their knowledge. Good luck and welcome….Beth
These users thanked the author Beth Mayer for the post: Wizard (Sat Jun 07, 2014 6:53 pm)
PostPosted: Sat Jun 07, 2014 8:48 pm
First name: Freeman
Last Name: Keller
Welcome, Wiz. You will get a lot of help and advice here - probably the first thing is to start reading and looking at as many build threads and blogs as you can. I started with a couple of kits and have gradually worked my way to what we fondly call "scratch" building - each guitar involved learning new skills and in some cases, buying new tools.
The advantages of a kit are that most of the hard work or things that require special tools will be done for you, but it is not just assembling parts - you will learn the wood working and other skills. Most kits have the sides bent, neck precarved, fretboard mitered - all these require special equipment. You will require some basic wood working tools and a few special luthier tools - its not uncommon to spend $500 or so getting tooled up. The one main power tool that you will need is a small router - this can be rented from Home Depot or similar when it comes time to install your binding. I once did a little tongue in cheek thread about my minimum shop for building my first couple of kits
http://www.kitguitarsforum.com/archives ... 46_0_5_0_C
You'll get good advice here at OLF but most of the people here aren't really building kits. A better forum is dedicated just to kits, you might hang out here in addition to OLF
http://www.kitguitarsforum.com/board/index.php
Next, you really should decide exactly what you want to build - kits are available for different steel and classical models. Stewart McDonald ("StewMac") sells nice dreadnaught and 000 kits, as well as many of the tools that we all use. If you do nothing else, download the free pdf of the plans for one of their kits - it will give you an idea of what you are getting into
http://www.stewmac.com/Materials_and_Su ... itar_Kits/
If you click on one of the kits there will be a tab that takes you to the instructions. My first guitar was similar to their 000, here is an old thread on its build
http://www.kitguitarsforum.com/archives ... 25_0_6_0_C
Another good source of kits is LMI, and they have a couple of classical models. They have something called the "kit wizard" (mmmm....) that lets you customize the basic offerings
https://www.lmii.com/products/mostly-wo ... kit-wizard
I built their Hauser copy as a gift for my son
http://www.kitguitarsforum.com/archives ... 86_0_6_0_C
Even tho it is not about kits, the one book that you should have in your library is Guitarmaking: Tradition and Technology by William Cumpiano. There are many other books, dvds and online resources - read them all. If you can hook up with experienced builders or take a class it will at least help with the special tools and methods.
Take your time, work carefully, ask questions here when something doesn't make sense. I happen to still be playing the first one that I made in 2006 - there is something very special about playing a guitar that you built.
These users thanked the author Freeman for the post (total 2): LanceK (Fri May 01, 2015 9:33 pm) • Wizard (Sat Jun 07, 2014 11:28 pm)
PostPosted: Mon Jun 09, 2014 2:37 am
First name: Wizard
Last Name: Kelly
City: Lafayete
State: LA
Thank you all for the advice!
PostPosted: Mon Jun 09, 2014 5:33 am
Country: Ireland
I was in a similar situation and I got a KMG kit and built it having barely ever handled a hacksaw. Ken's forum acousticguitarconstructionforum.com or something like that offered unending and patient support from KEn and other members. The quiality of the wood is also exceptional.
PostPosted: Mon Jun 09, 2014 9:52 am
Last Name: Sollod
All good advise here. I would also recommend getting this book...
Guitarmaking: Tradition and Technology by Jonathan Natelson and William Cumpiano
www.swiftcreekguitars.com
PostPosted: Mon Jun 16, 2014 2:23 am
Country: Ireland
I also found Kinkead's book very good, it assumes a certain level of woodworking skill but I found it good as a reference.
PostPosted: Sun Mar 15, 2015 8:14 pm
First name: Glenn
Last Name: Aycock
City: El Lago
Zip/Postal Code: 77586
I'll see your Cumpiano and Kinkead books and raise Bodanovich and Sloane. All of them are excellent resources, but Bogdanovich is full of colorful photos detailing jigs and work methods.
PostPosted: Fri May 01, 2015 8:54 pm
May I suggest getting a flea market chisel and learning to tune and sharpen it. Getting your tools into working condition is the largest hurdle in any woodworking endeavor. A junk chisel is cheap and will teach you a great deal. Like you, I'm new to Lutherie but I've spent lots of time developing tools and skills neccessary to this process. The chisel exercise helped me a lot.
-j
PostPosted: Wed Jun 03, 2015 7:01 pm
City: Lawrence
Zip/Postal Code: 66047
Lots of good advice.
May I also add that you to need to control the humidity in your work area.
If you don't it's going to bite you later on.
You also should look at some way to control the dust your going to be creating.
Safety first last and always!
Like Lance I started with a Martin kit, I wish their instructions where a little more comprehensive.
Building guitars is kind of like Lays potato chips few people can build just one.
PostPosted: Wed Jun 03, 2015 7:11 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
I started with 2 KMG kits, and they are an wonderful introduction to lutherie. Ken is keen on helping new luthiers get started and build their guitar without a massive investment in tools / jigs / unnecessary supplies. His kits are top quality, and gave me and others a great start.
If you go with a KMG kit, do not read anything other than Ken's Success Kit directions. The instructions he has written combined with the kits he offers, give you clear steps to success. It sounds silly saying that, but its true.
There an many, many great ways to build wonderful sounding instruments, but mixing methods on your first build can lead to heartache and unnecessary challenges. Follow one proven method to build your first - then start down the path of exploring different building approaches.
